I'm using the '1995 Pontiac Vin 1' xml file.
Try changing your vehicle definition settings to the same as these images.
I changed those particular settings and this is what I got:
51:51.211: Start macro: Clear diagnostic trouble codes: CLRDTC
51:51.226: Synchronising ALDL communications...
51:51.226: Waiting for heartbeat: $A1,$56
51:51.226: Waiting for Aldl bus silence of at least 20ms...
51:51.255: Start reading frame
51:51.300: Aldl frame header byte: $90
51:51.301: Aldl frame length byte: $59
51:51.307: Recv: $90,$59,$23,$02,$0E,$5D,$87
51:51.307: Finished reading frame
51:51.307: Frame: 0 = $90,$59,$23,$02,$0E,$5D,$87
51:51.307: Start reading frame
51:51.310: Aldl frame header byte: $91
51:51.312: Aldl frame length byte: $59
51:51.318: Recv: $91,$59,$02,$08,$FF,$34,$D9
51:51.318: Finished reading frame
51:51.318: Frame: 1 = $91,$59,$02,$08,$FF,$34,$D9
51:51.318: Start reading frame
51:51.325: Aldl frame header byte: $20
51:51.326: Aldl frame length byte: $5C
51:51.336: Recv: $20,$5C,$9E,$01,$00,$AF,$20,$00,$4C,$CA
51:51.336: Finished reading frame
51:51.336: Frame: 2 = $20,$5C,$9E,$01,$00,$AF,$20,$00,$4C,$CA
51:51.336: Start reading frame
51:51.400: Aldl frame header byte: $90
51:51.401: Aldl frame length byte: $59
51:51.407: Recv: $90,$59,$24,$02,$0E,$5D,$86
51:51.407: Finished reading frame
51:51.407: Frame: 3 = $90,$59,$24,$02,$0E,$5D,$86
51:51.407: Start reading frame
51:51.410: Aldl frame header byte: $91
51:51.411: Aldl frame length byte: $59
51:51.417: Recv: $91,$59,$02,$08,$FF,$34,$D9
51:51.417: Finished reading frame
51:51.417: Frame: 4 = $91,$59,$02,$08,$FF,$34,$D9
51:51.417: Start reading frame
51:51.425: Aldl frame header byte: $20
51:51.426: Aldl frame length byte: $5C
51:51.436: Recv: $20,$5C,$9E,$01,$00,$B0,$20,$00,$4C,$C9
51:51.436: Finished reading frame
51:51.436: Frame: 5 = $20,$5C,$9E,$01,$00,$B0,$20,$00,$4C,$C9
51:51.436: Start reading frame
51:51.499: Aldl frame header byte: $90
51:51.500: Aldl frame length byte: $59
51:51.506: Recv: $90,$59,$24,$02,$0E,$5D,$86
51:51.506: Finished reading frame
51:51.506: Frame: 6 = $90,$59,$24,$02,$0E,$5D,$86
51:51.506: Start reading frame
51:51.509: Aldl frame header byte: $91
51:51.510: Aldl frame length byte: $59
51:51.516: Recv: $91,$59,$02,$08,$FF,$34,$D9
51:51.516: Finished reading frame
51:51.516: Frame: 7 = $91,$59,$02,$08,$FF,$34,$D9
51:51.516: Start reading frame
51:51.524: Aldl frame header byte: $20
51:51.525: Aldl frame length byte: $5C
51:51.535: Recv: $20,$5C,$9E,$01,$00,$B1,$20,$00,$4C,$C8
51:51.535: Finished reading frame
51:51.535: Frame: 8 = $20,$5C,$9E,$01,$00,$B1,$20,$00,$4C,$C8
51:51.535: Start reading frame
51:51.550: Aldl frame header byte: $A8
51:51.551: Aldl frame length byte: $56
51:51.553: Recv: $A8,$56,$44,$BE
51:51.553: Finished reading frame
51:51.553: Frame: 9 = $A8,$56,$44,$BE
51:51.553: Start reading frame
51:51.556: Aldl frame header byte: $A9
51:51.557: Aldl frame length byte: $5A
51:51.565: Recv: $A9,$5A,$46,$00,$00,$00,$FF,$B8
51:51.565: Finished reading frame
51:51.565: Frame: 10 = $A9,$5A,$46,$00,$00,$00,$FF,$B8
51:51.565: Start reading frame
51:51.599: Aldl frame header byte: $90
51:51.600: Aldl frame length byte: $59
51:51.607: Recv: $90,$59,$25,$02,$0F,$5D,$84
51:51.607: Finished reading frame
51:51.607: Frame: 11 = $90,$59,$25,$02,$0F,$5D,$84
51:51.607: Start reading frame
51:51.609: Aldl frame header byte: $91
51:51.610: Aldl frame length byte: $59
51:51.616: Recv: $91,$59,$02,$08,$FF,$34,$D9
51:51.616: Finished reading frame
51:51.616: Frame: 12 = $91,$59,$02,$08,$FF,$34,$D9
51:51.616: Start reading frame
51:51.624: Aldl frame header byte: $20
51:51.625: Aldl frame length byte: $5C
51:51.635: Recv: $20,$5C,$9E,$01,$00,$B2,$20,$00,$4C,$C7
51:51.635: Finished reading frame
51:51.635: Frame: 13 = $20,$5C,$9E,$01,$00,$B2,$20,$00,$4C,$C7
51:51.635: Start reading frame
51:51.649: Aldl frame header byte: $A0
51:51.651: Aldl frame length byte: $55
51:51.652: Recv: $A0,$55,$0B
51:51.652: Finished reading frame
51:51.652: Frame: 14 = $A0,$55,$0B
51:51.652: Start reading frame
51:51.654: Aldl frame header byte: $A1
51:51.656: Aldl frame length byte: $56
51:51.658: Recv: $A1,$56,$00,$09
51:51.658: Finished reading frame
51:51.658: Frame: 15 = $A1,$56,$00,$09
51:51.658: Found heartbeat: $A1,$56,$00,$09 - ALDL synchronised
51:51.658: Send suspend command: $F4,$56,$08,$AE
51:51.658: Start writing frame
51:51.658: Send: $F4,$56,$08,$AE
51:51.659: Finished writing frame
51:51.659: Start reading frame
51:51.661: Aldl frame header byte: $F4
51:51.662: Aldl frame length byte: $56
51:51.664: Recv: $F4,$56,$08,$AE
51:51.664: Finished reading frame
51:51.664: MAX232 echo: $F4,$56,$08,$AE
51:51.664: Start reading frame
51:51.667: Aldl frame header byte: $F4
51:51.668: Aldl frame length byte: $56
51:51.671: Recv: $F4,$56,$08,$AE
51:51.671: Finished reading frame
51:51.671: Start writing frame
51:51.671: Send: $F4,$57,$0A,$00,$AB
51:51.672: Finished writing frame
51:51.672: Start reading frame
51:51.674: Aldl frame header byte: $F4
51:51.675: Aldl frame length byte: $57
51:51.678: Recv: $F4,$57,$0A,$00,$AB
51:51.678: Finished reading frame
51:51.678: MAX232 echo: $F4,$57,$0A,$00,$AB
51:51.678: Start reading frame
51:51.681: Aldl frame header byte: $F4
51:51.682: Aldl frame length byte: $56
51:51.685: Recv: $F4,$56,$0A,$AC
51:51.685: Finished reading frame
51:53.319: Resuming normal ALDL communications...
51:53.319: Send resume command: $F4,$56,$09,$AD
51:53.319: Start writing frame
51:53.319: Send: $F4,$56,$09,$AD
51:53.319: Finished writing frame
51:53.319: Start reading frame
51:53.321: Aldl frame header byte: $F4
51:53.323: Aldl frame length byte: $56
51:53.325: Recv: $F4,$56,$09,$AD
51:53.326: Finished reading frame
51:53.326: MAX232 echo: $F4,$56,$09,$AD
51:53.326: Start reading frame
51:53.328: Aldl frame header byte: $F4
51:53.330: Aldl frame length byte: $56
51:53.332: Recv: $F4,$56,$09,$AD
51:53.333: Finished reading frame
51:53.338: Stop macro: Clear diagnostic trouble codes: CLRDTC
Any more suggestions?
TIA.
Any more on this?
That trace shows the clear DTC macro and it worked perfectly and would have cleared any DTCs.
You should try logging data now...
Click on the "Engine data and DTCs (DATADTC)" macro, then click on the green "Start ALDL data".
You may want to turn off the View->Serial I/O option as that will slow it down.
It works!
Thanks a ton for the help guys.
Now I just have to pay for the license to get all the features. :)
