Originally Posted by dfe1
No, if I understand your original question correctly, the VE table is not a consideration. When you asked about the amount of air flow you need, I assumed your question was in reference to the "Desired Air Flow" table (B4307). If that's the case, that table has to do with the amount of air required for idle. The entries in this table typically have to be adjusted when a long duration camshaft is installed or any other modification that significantly alters idle air flow characteristics is done.
