Joel,
I had to install the config. file to get the ETC table.
Appreciate your ideas. You know I'll try everything, one at a time.
Joe
Joel,
Joe
You're welcome :DQuote:
Originally Posted by jfpilla
Keep us posted!!
joel
I'm excited. ETC works so far. In 4 flashes.
1- Returned Effective area to stock. No SOP or logging changes.
2- Increased ETC by 110% vs stock. It helped.
3- Increased ETC by 120 vs stock. Better.
4- Increased ETC by 125 vs stock(.0320). Right on
AFParked is stock also and has been for a while.
The trims are closer to 0 and closer side to side.
RPM's went up in P/N while cruising. I reduced Airflow in P/N.
It now transitions to idle before I come to a stop and stays at those rpm's.
It idles smoother, believe it or not.
I will have to log from a cold start and drive from a cold start and see if learning occurs, before I get too excited.
Let me add some thanks.
I told Nick that Eff.Area did not seem to work. He felt it was for F_bodies and suggested I try ETC.
Flashscan, the tables to get it done, along with the ease and speed of the setup, really make tuning possible and fun. Thanks to Paul, Ross et al.
Very cool Joe.....
And I'm in California this weekend tuning, and Paul is the absolute man, he got me out of a huge bind when my dongle bit the dust, I can't thank him enough for helping to ensure the trip wasn't a total loss. Over the weekend no less! (He tuned his car yesterday, crossing my fingers he got great results.)
And the stuff we keep learning here is proof that if you're NOT learning every day, you're going backwards.
And I can wait to get that danged LS2 I built you on the rollers and see what it'll do!!
take it easy.....
-jeff
I did more logging today and found that setting B4349 at .0330 was even closer.Quote:
Set B4350 at 100 and could not see any difference.
Idle airflow is affected by changing B4349. Since I'm at the SOP stage I'll have to wait for cooler weather to get it right across all airflow temps. It's so hot that the temps move right up to 105C too fast.
Jeff is Jeff Creech of Carolina Auto Masters. As soon as he can find dyno time for me I'll be there. The car feels very strong.Quote:
Originally Posted by milkman
Here's my Idle Airflow table. It's close to stock. I think it could be if not for the 90mm TB. Needs cold weather tuning.
LABELS Idle Airflow (Grams/Second)
ECT °C {link: SAE.ECT} In Gear Park/Neutral
-40- 20.000000 ---18.849609
-28- 18.500000 ---17.469727
-16- 17.000000 ---16.200195
-4- 15.500000---15.240234
8- 14.400391 ---14.549805
20- 13.500000 ---14.259766
32- 12.240234 ---13.009766
44- 11.339844 ---11.419922
56- 11.000000 ---10.564453
68- 10.700195 ---10.129883
80- 9.200195 ---7.405273
92- 7.849609---7.200195
104- 7.740234---6.949219
116- 7.740234---6.949219
128- 7.740234---6.949219
140- 7.740234---6.949219
