I noticed my Burb running a little better on 08322...don't really know why???
Yeah...exact same cal's. Don't know why the difference.
If you downloaded the zip file ... open the "Read Me.txt" file - use Notepad (not Word) to open it - then follow the instructions. If a *.cax file was downloaded that matches your OS - then you are good to go.
You will also need to populate B3634 to B3639, and B3646 with values from a Holden vehicle originally equipped with LC (Lean Cruise).
Also, the values in B3639 are in EQ - these are SUBTRACTED from your current stoich value (EQ = 1.00) to arrive at calculated LC fueling.
While in LC mode there is NO input from the O2 sensors (i.e. no STFT) - the tune will be running directly off the VE table - so this must be reasonably accurate to avoid excessively lean mixtures. The OEM often setup LC to run as lean as EQ 0.8574 (roughly an AFR of 17:1 if your stoich was 14.68:1)
Regards,
Taz
Read Me file: Extract this zip in to \Program Files\EFILive\V7.5\Calibrations
OK, I'm obviously doing something wrong or missing something.
In attempt to download the zip file I went from C: -> program files -> EFILive ...
After opening the EFILive folder there was only the 'V8' folder available, no V7.5...
When I downloaded the zip temporarily to 'My documents' and opened it from there, then I had a choice of V7.5...
Once in the V7.5 file, there were several files in but I did not see any 'calibration file' into which to download your zip file.
What did I do wrong or what am I missing?
The folder is named C:\Program Files\EFILive\V7.5\Calibrations
Browse to that folder and extract the zip file there.
