i'm not real knowledgeable about efi yet, so what does that mean?? you have to have the module and a laptop for that?? also i know OS is operating system, but i'm not real sure exactly how it works... :confused:
I think he means that the V2 keypad/LCD allows you to switch tunes.
What I mean is you install a custom os with your v2 and laptop. A DSP5 tune. Once you have it installed, you can switch to one of the five tunes with the v2 device. No need for switches.
x2 on duramaxtuner.com. Nick hooked me up with my V2 with DSP5, and he's been nothing but helpful with every question I've had. I was also very impressed with the tunes he made up for me. IMO
As for the Switching tunes with the V2, i see you have a 2003 also and depending on your OS# you might want to hold of on V2 switching until they get the bugs figured out with the random limp like modes. http://forum.efilive.com/showthread....9819#post79819
The only reason i say this is I'm one of the ones having this problem, and its really a pain.
correct me if i'm wrong, but isn't the difference between DSP2 and DSP5 2 and 5 different tunes?? cuz i thought they were havin' problems with the DSP5 and not the DSP2. i thought the two position switch was all worked out and they were only havin' problems switching between 5 different tunes. if that's not the case could somebody please fill me in. i really want to know about this stuff before i get it.
Its just 1 OS for the LLY thats having an issue, post up your OS # (if you know it) and you cant switch DSP2 tunes with a V2, have to put a switch in.
Yeah the problem is only with the new DSP5 operating system that is set up to change via the V2 handheld.
Its actually one of the LB7 OS# that is having the problems.
FYI, the issue with had with the new DSP5 OS is fixed (It only affected LB7 OS's converted from 15189044), all others have had no problems reported. They (LB7 & LLY) will be officially released from Beta state with the next software release.
Ross,
So the random limp mode is fixed, but those of us with the problem wont be able to fix it till the next release?
