Thats what i was thinking. I guess i will go look for MS Excel
The calculator is now including in the EFILive tuning tool.
For the 5.9s, yes. Is it usable with the 6.7s in excel?
Fair enough, I missed that in your sig.
The next update will include the timing calculator for the 6.7L as well.
So, I just want to be sure about this. The timing calculator that is included in the latest v7.5 update is very much like the josh h calculator where we want the percentage to be at about 50% across the board as a ballpark number? I am asking because I used the josh h calculator to build my timing table, and have only made a few small changes, but my table ranges from 26-63% when viewed on the v7.5 calculator.Quote:
First, the calculator is relative to pressure, so if you have changed fuel pressure it will change your percentage when you run the calculator. Second, the stock timing/pressures don't produce 50% across the board. If your timing and pressure are similar to stock then your percentages will reflect that.
Thanks, I should have clarified since i was posting in the 5.9 section.
Super, thanks.
