im not sure what you mean with rafpn somethin air flow park neutal and in gear but what am i watching or log lbs/per min on the iac?
You need to log the idle trims (not fuel related). See this thread for detail:
http://forum.efilive.com/showthread....2291#post52291
here is my log and the average is .01. im lost you can see the idle going up and down
Sorry to respond so late - don't appear to have a subscription to this thread.
I couldn't view your log on this laptop (still on v7.4). So, I took a stab in the dark. The changes made can be found on the History tab right when you open the tune. Try out those new tables in your current tune and see if it's any better.
Just a word of caution. The timing values you have seem "different" to me. I don't know many setups that like that much timing in the low RPM, mid-low airflow regions....and with the idle over/underspeed timing controls limited to +/- 2*, that might be the cause of your idle swing issue. I primarily adjusted the IAC related tables that I thought would help improve your idle. But, you might want to consider reworking the timing settings you have.
Related material that references this thread: Idle-Tips-amp-Tricks
[ this is a note to myself as I organize stuff ]
MAF and VE have to be correct; then idle air has to be adjusted to match the actual air that is bypassed in the throttle body.
Created a pdf merging post 1 & 8 for this newb to follow.
Good deal :cheers: thanks for posting.
ttt
Photobucket delete on the maps on first page. Need updated.
pdf was made. see post #48
