Thanks Steve:
I'll keep the calc_pids.txt on file. Sometimes different OS's have different Values, but I really appreciate the effort.
Thanks again..
Shawn,
Got to make my first log tonite. I had some issues earlier today with it. It wouldnt go into closed loop at all, and I had no o2 sensor data. I found that I switched two wires for bank 2 sensor 1 and 2 around doing my pcm swap. Anyway I got that fixed and fired her up. Took a while to get into closed loop and the trims to start, (o2 data doesnt show right in my dashboard, but does in data tab, wanted to log it just to see. It did work right last year).
At any rate most of the drive the trims averaged around -14% for the trip. I beleive I have the maps set up correctly, but in order to paste with lables on the ve table it really messes it up. I think I will start over I think I missed checking the Names box when I made the maps. I dont know what diff that makes. Take a look at the log and see what you think. (was a little hard to idle, I want the ve dialed before messing with idle)
This is the tune that is currently in the car, and what I will modify from as well
Len, I think that looks like a pretty decent log.
I have your SELBENS averaging more like a -7 to -9. As I have said before, Tuning with negative Trims is a lot easier than positive.
On your VE MAP, make sure the columns.rows line up with your VE table. Here is what I came up with using a tight VE Filter..
A log like this is really only 1-2 more runs from perfection..
I am pretty sure that my columns and rows match, but it displays it like the auto ve, or what i did for calc ve last year. IE: 1.27, 1.14 ect. Yours screen shot displays it in the same units as the table. Same thing for the maf table. But with the maf you paste and multiply. (I did that and came up with a few high ones I will have to smooth.
Maybe this is the issue..
NOTE: use the CALC.VE pid units that match your B0101 table, i.e. either % or g*K.kPa.
I checked that to make sure. and the table in my tune is kpa and my map is set up kpa. I will try building the map from scratch again in a little bit.
Yea, it was my map. I took for granted that it displayed in kpa, I now see that in the units it says %. Boy that makes a difference. I will get some more logs today before the storms start.
On the map's Data, Row, Col tabs, checkmark Show Units, sand re-save the map... this helps avoid confusion.
Well, for some reason this map is kickin my butt. I have it set to % in the parameter. I made sure tune is % and all I get are 0.00 for data from the log. If I change the tune tool to read in kpa, I get data, but not if I have everything set to %. I will attach the last log and tune. Something doesnt seem right.
Hell, dont know why, but i opened it up on here and then again in my log and it worked just fine. Table looks not that good when pasted. I just love computers. That has been my biggest hurdle to deal with.
