Kool beans man!
Kool beans man!
Thanks for all the help guys, I am running on OS5....now on to tuning!
Jason.
Jason, make sure you have the updated 02020005.cal file.
So you see which two folders they belong in (along with all the other .tun and .cal files)... :cheers:
I'm pretty sure I have the updated one...is there an easy way to tell?Quote:
Originally Posted by joecar
Jason.
The file's timestamp says 7/13/2006 6:48pm.
The tune tool is telling me that some of the Axxxx parameters are out of range...
see composite pic:
http://img238.imageshack.us/img238/8...rrange0qo2.png
But when I eyeball each one, it's value is equal to the maxium value, so how can it be "out of range"...?
What software rev are you running?
I'm running this one (Feb 24, 2007): showthread.php?t=4585
The reason why I asked is I am running the same rev with COS #5 and an underlying 12212156 base and donot have this problem. I have a buddy that has an 03 Silverado RCSB w/ the 1MB pcm running COS#3 with the same problem.
Set all the values joe to somewhere in the middle and save the tune. Re-open it and then change them back to the max value and see what happens.
