Jody,
[red = do this one time]
Ok, now connect V2 to PC (for power);
On V2 LCD/keypad navigate down into setup options, select the SD card, and format it; when done, go back to the opening menu.
Then on PC, open EE, goto Config Files tab, click Format (formats the config space).
Then drag these files from upper pane (PC) to lower pane (V2):
- LS1B_A.pmm <--- means: 1999+ LS1 with A4
- Options.txt <---- the same one you copied
Then, goto Scan Data tab, and drag the 4 dtc files from upper to lowe pane (useful for interpreting DTCs).
Then exit EE, remove V2 from PC.
[green = do this each time you log]
Now goto car, ignition key on, connect V2 to car.
If you haven't done this already, or if you want to change pid list do this:
On V2 display, go into Select Pids...
It shows various "pid lists" (i.e. named lists/groups of pids),
Select one of those (e.g. LOOP or TRANS).
Press OK one more time.
Press the ZERO key to start logging.
When finished logging, press CANCEL two times, remove V2 from car.
Connect V2 to PC, Start EE, goto Scan Data tab, drag log files from lower pane (V2) to upper pane (some folder on your PC, you may want to change to a different folder).
In the lower pane, you can delete the log files.
Exit EE.
Using scantool, open those log files.
