Deleted 6.7 throws "See dealer for service" message on overhead display.
Quote:
Originally Posted by
2007 5.9
So you get a OHD warming to see dealer and a cel but no codes?
Mine does the same thing once I hit the highway or interstate and maintain a steady rpm over 1900. I have one tune that doesn't do it. But the only thing different from the others is timing, turbo control, and fuel quantity. Other than that everything is the same.
There is a timer we are testing to delay the ding/OHD, stock is 10min.
We can adjust that up to 360min.
If you like you could send me the tune in stock form, ill adjust the timer and send it back and you can write your tune on top of it and test if it helps.
mikebol
Any update on a permanent fix for this message?
My truck throws a P242D at about 30 minutes into each drive. My tuner has turned off the code so I don't get a CEL but the overhead message and ding still persist. Fortunately for me there is only one ding per drive, not a persistent dinging. I suspect others are throwing more codes than I am which is why the overhead is more persistent.
For now I consider myself lucky, but I sure wish I could use a SIM or something to satisfy the computer.
Mike
As I posted above there is a fix via the timer..ask your tuner to turn the timer up.
LBZoom
Can you tell me what the table # is? I just briefly browsed through a 6.7 tune with the newest v7.5 software release and didn't come across it.... thanks!
It's not public yet...if you shoot me your tune, ill fix it and see if it works.
