Anyone have the P/N for the little gasket that goes on the MAP sensor and keeps it firmly in place on the back of the intake? I noticed the gasket on my old MAP sensor was torn in a couple of places while removing it.
:cheers:
:cheers:
Why did you have to downconvert from an 03 OS to an 02 OS? Is there not a COS for your 03 OS?
From what I've gathered, there are only two different versions of COS5 -- one for US spec cars and one for AUS spec cars (did I get that right?) The one for US spec cars is a direct upgrade for a specific 2002 OS, so converting to that OS first and copying the tables over makes the actual COS flash pretty straightforward.Quote:
Originally Posted by ScarabEpic22
I doubt there are any real functional differences between the OEM OS in my 2003 and the 2002 OS I had to downgrade (sidegrade?) to first.
That's correct: 12212156 -> 02020005
OK, I guess that makes a lot more sense than having about 205484 versions for each and every OS from 02-07+.:bash:Quote:
Originally Posted by joecar
I first had to go to 12212156 on my 2001 Camaro. Then a hour or less of copy-paste and then to 005. It was not too bad.Quote:
Bill
:cheers:
Am I missing something? I don't have 02020005 in my Custom OS folder -- clean install off the downloads page.
Brains, see attachments (...zip file failed to upload...)...
These were gotten by following post #204: showpost.php?p=46950&postcount=204
Edit: These files are already included in the later builds of EFILive software.
Ahh, thank you very much !! I skimmed this thread, and went right over it. :cheers:
Was the tutorial ever completed for this or am i over looking it? I am having a bit of trouble following the info in this thread :)
..RJ..
