I'm not getting "sane" numbers on my BEN correction maps. 5,000 rpm and 100kpa might read .011 or something close and the lower the rpm/kpa the closer the values are to my actual ve table. This started as soon as I went to speed density.
Maybe I should just give up on these SD80s and get some ID1000s...
Post a screenshot of what you are seeing.
+1 screenshots... and tune/log files.
You may have to play around with A0014 and A0008 to achieve the desired results, seems I had the same problem with a stock setup and that is how I resolved it.
Here is a screenshot of the insane values that I'm getting and check out the ve table that's actually working for my car. To me the ve table looks terrible but this is what gets the car to run well. I'm still unsure of the injector characterization values I'm using but it's like pulling teeth finding proper values. Once again thanks to everyone for helping me with this. I know you are all busy people and you by no means owe me anything.
Attachment 16987Attachment 16988
Screenshot attachment link is broken...
VE does look pretty ordinary, but it'll never run nice with B3647 the way it is - apart from 2 cells, it hasn't been fixed up since you converted to a COS.
You've mentioned the AFRs you're getting, but you need to look at what it is you are commanding.
BEN numbers certainly look wrong, but it's difficult to offer any further analysis or insight without a log. Can you past the log that made that map?
Is your IAT sensor integrated into your MAF sensor?
