There is a hack for Analog WBO2
Analog WBO2
Analog WBO2
No, IRC Paul saying something about using a connection that programs the AutoCal from the factory.
The search sucks now so I can't find it. :bangin:
There is a serial header inside the AutoCal device physically which is used at the factory (internally) for programming the devices.
Even if you were to connect to this header the problem you'd have is that the AutoCal firmware does not have the serial capability enabled, so it wouldn't function anyway.
The LC1 comes with a serial cable.......connect it to your lap top and create a PID for it.
Im not sure how much longer efilive are planning on making the existing V1 controller, but i thought that with both the v2 and autocal unit supporting both can can/vpw it would be a no brainer to phase out the v1 hardware as it does not support serial WB.
Then people who only want to scan/datalog could use the autocal unit. If you want to edit the tunes you buy the v2 hardware.
Personally i would then use the autocal unit for datalogging at the drags, motorsport events etc due to the smaller size.
