Originally Posted by
Tre-Cool
while not related to the beta & instead of starting a new thread. can you take a look at the 7.5 definition for t43 os 24256025 and see what is configured at the following address - 1F652A
I have a cax file defining it as below but get a conflict, but i can make a change in the binary directly and do a compare & efi does not see any changes. (V8 runs fine, but im lazy and still use v7 format/editor)
[D9812]
; Description
DESC.001 = Remove requirement for a Tap Shift movement before enabling Manual Mode
DESC.002 = Removes SPORTS MODE.
DESC.003 =
; Seg Caption Major Minor Vis Dis 2D Grp
VIEW = 4 "Up/Down Requirement" "Shift Control" "" 1 1 0 0
; Address(es) BitOff Bits Typ Inv
ADDR = 1F652A 0 8 SED
Cheers
