Here is fueling states list I have for those interested. It is old FYI
https://mega.nz/file/Uy4y0QwR#WYLVo3...8VB2mO8O8gzAW8
i have same issue also, problem is that efi never mapped the torque management tables. i have figured out they are related to the speed inputs. the ecm thinks it's destroying the drive train so it's trying to save itself. i reallly wish they would add this to program or if someone else could find and map this it would be awesome.
Has anyone every figured out this code 45? I keep hitting it.
Post your file.
They are maxed. Tried keeping it under 126mm3 because count 45 limits at 126mm3 at 3500. I need a .cax file but no one wants to share hex files so I can look through it. Just doing this as a hobby and everyone makes it’s so difficult.
Bumping this up. Has any resolution been found for this? I'm finding that on the logs from my OS that the transition from governor status 7 to governor status 45 is tied directly to crossing any duration command above 1600uS. This causes a plateau on the fuel command, a "derate', that would otherwise continued on a nice upward slope. I will post some screenshots when I can get back to them.
Sent from my motorola one 5G using Tapatalk
Attachment 24276
I found another log that appears to be 1500uS. I am going to get another log today as this one is over a year old.
You will not be able to reach full fuel in a stand-alone setup without help outside of EFILive. I have posted about it. There are several Limiters not provided in EFILive. You can use Hp Tuners for a single tune or find someone to write you up a CAX file.
