That's what I was thinking too. But, who in their right mind would use a TechII, that thing is slow as molasses, on the E38 it's about 18 minutes to program it!!
The software I have seen that GM uses was nothing like EFI Live it was all done using code, why would you spend hours in code and pulling the pcm all the time vs just using EFI Live? Also how are they data logging, with a tech II?
I wonder if the tuner actually has the proprietary tools to program/customize the actual OS, in addition to modifying the calibration tables/params? Without hearing more, I cannot speculate as to why someone would choose to develop a calibration this way.
Mr. P.
I have been following this on the vette forum,Now that I'm thinking,Are you or the tuner sure its a 1514 code and not a 1516 or 1518 code? The only reason I ask is I was getting a 1518 code and it has to do with the TAC module and my car would go into reduced power mode once in awhile on start up,Long story short,My TAC module is fine, It had something to do with my TB and a table in the red folder in EFILive(ETC table's).I posted all over EFILive and got no answer's,No offense anybody :) But I figured it out myself and everything is fine now.Just a thought...........Paul
Paul, I saw your posts regarding B2713, I'm sorry I do not know the answer.
I also saw your post and did not have an answer, I have never modified those tables in
any of my tunes. I don't see how they would cause you a problem unless you changed
them to begin with ??
-Justin
One thing I learned from experience, NEVER update your PCM's OS. Keep the OS orginal. Doing that will affect a lot electrical problems on your vehicle including a bad pcm from what you experience. Lesson learn...
