Ok, but I can't enable it because I loaded cax b above and B9100 (LC Enable) is gone. LC worked great, before I "upgraded" to build 235.
Take the [B9100] section from your old cax file and add it to the end of your new cax file...
Ok. B9100 is back but predictably so is the error message on startup.
Post a screenshot, and post your cax file.
upgrade to the latest version, then in settings there is an option to allow cax additions in other memory areas for older controllers. I dont have EFILive on this computer but if you have the latest version off the website have a look through the settings section and you will find it.
+1 what kangsta said (I forgot that this option got added)...
Edit->Properties->Options and see "Allow cax files to modify...".
Works perfect now, thanks guys!!!
Can you try your original cax file with the "allow cax option" checked and see if you get any error messages?
I loaded my original cax file and do not get the error message.
Ok, the error message is back. I loaded COS5 and it works fine, 02020005. Then I copied the latest 12212156.cax, renamed it to 02020005.cax and put it here C:\Program Files\EFILive\V7.5\Calibrations. The option to "Allow *.cax Files..." is checked. Here is the error message:
