Anyone knows why the efilive changes the tune automaticly?
Nothing is wrong, the LEDs signify the following (from left to right):
Green: Black box logging is active
Orange: Coms with serial device (i.e. wide band O2 controller)
Blue: FlashScan is writing to flash card or internal memory (do not unplug while blue LED is on).
Orange: comms with vehicle.
Green: comms with PC.
EFILive does not make changes to the tune automatically except under the the following conditions:
An out of range value is detected in the *.tun file. Even in this case, an update will not be made to the *.tun file unless you open/view the out of range values. You will also be notified that EFILive has detected out of range calibrations.
If you click on the [Apply] button on the [Shift Point Correction] tab page of the speedo calculator.
Well it did on this after every tune. look at the difference
Attachment 4984
Attachment 4985
Like i said, That is the same one. Right after i reflash the first tune, the second one occurred w/ adjustments that I "DID NOT" made was the result of after flashing the first tune.
Here is what the scanner says
DTC Clase 2 Data Link Status: PHC Power Control Module (PCM)
and I notice this on the tune that says "Not Connected" even though the flash went through.
http://img12.imageshack.us/img12/9210/tune.jpg
That picture shows the "Not connected" status of a RoadRunner controller. Are you using a RoadRunner?
Thats the RR control panel, absolutely nothing to do with EFILive's FlashScan modules.
This is getting ridiculous, post up the last tune that WORKED (name it accordingly) and post up the tune you're TRYING to flash. List EXACTLY what you've changed, everything.
Sorry if Im coming off pi$$ed off, Im not just frustrated because I know the tunes Ive sent ya will work, they do in my 02. And this weeks been hectic as anything...the joys of college right?
