P0106: get this fixed... for example see 2001 Corvette DTC P0106
Are you running with a MAF...? If so then you will have to get the MAF table corrected using a wideband.
Then (regardless of MAF or no MAF), you will have to the VE table corrected (also using a wideband).
yes i am still running the maf but plan to later go mafless, i will work on getting this fixed.
can i correct the maf table with wb , while i still have this code or do i have to fix 0106 first ? just changed OS and never had this code till swapped OS5 into car , is the stock map ok for this OS5 or do i need a 2 or 3 bar sensor? watching sensor on pid looks ok
Fix P0106 first.
What MAP sensor do you have...?
What OS did you change from and to...?
os was 12593358 2001 corvette to 122212156 2002 corvette to 02020005 =os5 map sensor stock not shure of the part number , dont think its ever been changed.
In the engine diagnostics segment of the tunefile, you may have to edit the MAF and MAP sanity tables.
Your cam (236/242 114) has 11 degrees overlap, so MAP is significantly different than stock at low rpm.
ohhh am sorry to waste your time , my fault i guess i missed copy and paste on that one, damn! i do also have a code for srs 1001 is there a way i messed this up to or does it have to do with os swap, never had it before . how or where do i go to fix this one . thanks joe!
so i think that when i flashed the 12221256 in it may have the wrong vin is that poss and the sdm is seeing this ? I do have the correct vin in there now with cos 5, but still see the 1001 code. any ideas would be greatly appreciated!
You can just write the correct VIN using the V7 scantool... yes the SDM most likely wants to see the same VIN as itself.
