That is correct. It depends how it is wired, what tune is in it, and what reluctor ring is installed. It will run a CMP sensor/distributor or Coil Near Plug.
Jeff
Jeff
Wow, thanks for the quick reply. By "by how it is wired", does that mean there is a different pin-out for the Red & Blue PCM connectors. One pin-out for the 24 tooth wheel and a different pin-out for the 4 tooth wheel? If there is a difference where can I get the pin-out diagram for the 4 tooth or a list of the differences?
Wes
How it is wired--means there are more wires for the 8 coils. I have 3 different truck wiring files for the 0411 swap. 96,97,98-2000. If you want to run CNP there is a small additional wiring file to these 3.
Jeff
yes, the 411 will work with either a 4x or 24x reluctor. However, you cannot run a coil per cylinder setup with a 4x reluctor, that is the benefit behind swapping to the 24x reluctor from eficonnection. but thats with a vortec L31 motor. but, if you're running an LT1 setup like in a 93-97 Fbody, you need the 24x swap to run the 411.
Thanks. About 10 seconds after my last post it hit me that the additional wiring would have been for the 8 coils.
Wes
