Goto that map, edit properties on that map, goto Data tab, select AFR_LC11 for the data.
(post a screenshot of your map properties Data tab display).
Okay everybody, here is what I see when I am logging AFR??
http://img17.imageshack.us/img17/5517/afrlog.png
http://img17.imageshack.us/img17/9439/mapproperties.png
Here is what I have for properties on my tuning software
http://img15.imageshack.us/img15/729...properties.png
Any ideas?
Thanks,
Glenn
Just for the hell of it, try this MAP with that log.
Attachment 4960
Okay I will try it later this week.
Why do you think this will work?
thanks,
Glenn
I just opened your log with this map and AFR displayed properly,
maybe your MAP is corrupted or something.
Try using the map shown in the attached image... (this is what mr.prick and I see from your log file).
Okay I will try it, but how does it monitor my boost VE?
Thanks,
Glenn
Try it to see if it shows the right numbers... if ok, then edit the columns to cover your boost range (and save with a new filename).
Ahh haa, I knew you guys would be on top of this:hihi:
Hopefully will have more info within the next few days.
Thanks,
Glenn
Okay, good news. It worked.
However, when I added more columns for my boost VE to fit into you can't see the whole AFR number. See below.
http://img264.imageshack.us/img264/3361/newafrtable.png
My old AFR table did not have this problem. Any advice on how to shift the number over in the cell so you can see it or shrink the number so you can see it?
thanks,
glenn
