Where are you located?
Alex
savannah ga usa
still hangs had the os updated at the dealer and its gotten better but will still hang
What is this in?
MAF is topping out where you are having trouble (or at least it is hitting 512g/s) - which could be a problem in itself. Calc torque would be very high, but it is not logged.
512g/s at 6000rpm is some seriously nice power :).
Is TM on or off ?
Hi stall or stock converter? (EDIT: found that answer: stock).
ive extended the time shortened the time tm on/off and now with the 2800 stall convereter its hell
