okay i fallowed step by step, did a run and loged some data, when it would idle to about 1500-2000 rpm the wb02 would be tacked out at 18:1 but once i got going it entered PE iam guessing and would stay around 12:1. so i did a quick log and figured i would try and adjust the ve table a little just to smooth out the lean-ness and then do some longer better runs so iam not surging as much on take off. i copied with labels and pasted and multiplied with lables and it was REALLY spiky! like it maxed out some cells at 10000!!!
