Please Email the tune to [email protected]
On the way now.
Got the file, thanks.
I though the gm stage2 flash was locked? I thought guys could tune the stock turbo pcm, but if they get the stage2 flashed in it was locked. Is this correct?
Apparently not, the file appears to be 100% complete.
Hmm. Didnt it used to be that these guys had two choices? Either tune the stock turbo pcm with hpt, with not many tables supported. Or get the Gm tune flashed in and not be able to edit it at all. Just run what Gm had put in the Stage2 tune. And that was supposedly lacking in areas. But now I guess you can edit the stage 2 flash.
Ross,
I'll get you a read on a Pontiac G8 and let you know.
Been waiting on this forever!!!
Thanks!
