Originally Posted by
Blacky
The message "script file not supported by this software version" should only occur if/when the software version and the script file version are not compatible. For the current release, the software version is V8.2.1.155 and the script file version is 08.02.34. Follow the instructions below to verify/validate the version number of the files that have been installed (or failed to install) on your system.
Check the version of the V8 software and make sure it shows V8.2.1. Build 155 on the main screen as per the first image below.
Check the version of the C:\Program Files (x86)\EFILive\V8\EFILive_VM.dll file, to do that right click on it and select Properties, then select the Details page (or the Version page if you're using WinXP). Make sure the version number shows as 8.2.1.155 as per the second image below
Check the version of the CMB_R.obj script file, to do that run Notepad and from within Notepad open the script file C:\Program Files (x86)\EFILive\V8\Config\CMB_R.obj. Make sure the version number is 08.02.34 as shown in the third image below. Close Notepad without modifying or saving the file.
IMPORTANT: Do not attempt to modify or save the script file while viewing it in Notepad, it will corrupt the file. Only use Notepad to view the version number.
