DHP did Cal only flashes... I
sooo ummmmmmmmmm is their hope? sure dont want to throw an etra 350 to another company when I could buy a lic to do what I want and poss sell a cng conversion setup for some of these turdds around here. CNG is hot in utard (Utah) id like to be able to flip a switch like you would w N2o and have the ecm change fuel mapping to actually run another set of injectors that I will build a board to switch back and fourth between sets (gas/cng)
Custom os with switches would be out of the question, Not enough interest/vs time/income for that one.....
hmmmmmm how could i setup the cng injection to be controlled by the ecm and not have a huge difference in mapping. I guess Id need to tune it via pressure and wideband o2 to keep it within fuel trims? next issue is the timming increase. would you think the ecm will keep pushing timing limets fast enough and far enough to regain some of the lost power?
I'm not criticising DHP with this comment, but I think you had to make sure you were flashing in the right thing because if it was wrong it bricked the PCM?
And that is part of the problem with the V6 PCM, the OS spills in to the calibration area (defined by the Flash memory block sizes), so if you do a cal flash you have to be 100% sure the OS portion is the same.
Nothing will happen as a beta in any shape or form this year, we are already behind on other things. Plus, we've travelled this road before and it never happened.
What wait4me said.
Good Point, RR works on the V6 PCM.
A road runner would be extremely killer for these ECUs.
I do see the lack of market. People that right now are into these cars don't want to pay for tuning, but then again, they might do it themselves... I think there might be market and suddenly they spark again. The newer superchargers fit these older engines and there are a lot of turbo kits and centrifugal superchargers available for them.
Horrible coding in the V6 PCMs, sounds like the P10 all over again?
(Ross and Jesse are gonna kill/ban me now...uh oh!)
It would be pretty sweet. I love the torque on those engines, and they have quite a following.
What about a different ecm that IS supported by EFI? like what would you go after and I can just grab an ecm from a car in one of the yards here.
Dam I wish id have finished elementary/middle/ high school and collage I might have ben able to unserstand some of this programmin stuffs
