Originally Posted by
vzsv8
There is a readme file inside the zip, it says.
Extract this zip in to :\Program Files\EFILive\V7.5\Calibrations
When you next load a tune file you will see a option at the bottom of the engine segment, look for parameter B9000.
I never found B9000 but there is a new entry at the bottom of the engine segment, exactly as stated, called 'bad things inside'. This contains an option enable/disable lean cruise. It also states that all the maps and parameters also need to be set up as per the Holden calibrations and then you you do a full flash. Then if it works.:cucumber:
All the Holden info is available at Holdencrazy.
Good luck, Steve
