Quote:
Originally Posted by black02ss
Keith says that it needs to be smooth because of the interpolation of the cells, where I have stated since day one like Ross did, its what the car wants and what is what the wideband tells me it needs. So is there really a correct way or is it just a personal preference? I have tried to smooth and make it look perty, but it just doesn't seem to work as my actual differes greatly from my commanded.
Keith has a point in that you would not get away with BIG differences between cells, smoothing is helpful there, but as Rick said (hope it was you Rick) your first log of the BEN factor might produce some spikey areas, smoothing on the first pass would be a good idea to get things in the ballpark, then logs done after that will be pretty much what the engine wants, it does depend on how crazy you want to get with this stuff, but because the PCM can interpolate (256 from memory) values between the cells so you are never going to hit the same points at say 2000 - 2400 and 55 - 60kPa, so between those cells the PCM may calculate a VE number of 1.203 or 1.209 or 1.198 etc (I did a thread on that somewhere), the more logging you do, the more correction you apply will pretty much reduce those error factors.
You are always fighting the PCM interpolating between the cells, the idea is to narrow the range of that interpolation by either 'measuring it' or 'smoothing' it which is a calculated correction.
I don't spend 8hrs a day tuning cars so I just can't say 100% that you should not use smoothing all the time, mathematically it doesn't make sense to me to do it that way. But practically I'd love to hear from others, I found on my own car making the graph look like a babies blanket screwed my WBO2 values.
Delco, if you wouldn't mind passing on your eperiences with your car that would be good, I know that thing has a BEN factor of what 1.0001 everywhere!!.
Cheers
