it will effect fueling where MAF and MAP are blended but will have no effect above the default 4000rpm that is exclusive MAF fueling.Quote:
so under 4k you could adjust the ve and above 4000 adjust the scaling. Of course that could lead to a jump around 4k+.Quote:
Originally Posted by macca_779
Its more for a case of the VE is dialed in now and the MAF scaled but to fine tune with the 2 was just wondering about the effect adjusting the ve would be
The question is what sensors are used in the rafig process to determine desired airflow.Quote:
Originally Posted by dfe1
Lets get this right. Maf or Speed density has no relation at all to this calculation. it is a difference to actual & desired idle speed & nothing else.
I think there's more confusion here than anything else. When you go thorugh the RAFIG process, what you're trying to do is establish the proper desired air flow for the specified desired idle speed. If you look at the RAFIG PID, you'll see that it is simply the sum of long and short term idle air correction. If desired air flow data was perfectly correlated to desired idle speed, RAFIG would equal zero because both long term and short term IAC correction would be zero.Quote:
Originally Posted by 5.7ute
Hey Joel, how you doing :cheers:
Ok, thanks, I added this to the following thread: showthread.php?14188-Summary-Notes
[ one day I'll organize all the info :hihi: ]
