V2 already records MAP in kPa.
In your scantool, on the PIDs tab, rightclick on MAP and select Metric.
Hi, I hope you guys can help me. I just did the bbl upgrade, upgraded the 2.4.72, then 5.8.18fw.
I have the V7.5.74 and V8.1
I'm trying to log with an LC1-serial cause my A/D volt inputs are burnt. Now I'm stuck trying to find why I'm missing an Option.ini file, it also seems I've lost all my VINs.
Any help would be much appreciated....
The ini file I presume you're looking for is Options.ini. That is meant to be in the folder:
\Program Files\EFILive\V8.1\Config
however, it got misplaced in the last software update and now it gets installed in the folder: \Program Files\EFILive\V8.1\Programs
You can check which licenses on your V2 cable are used/unused by using the menu option (on FlashScan): F4 Options -> F3 Licensing -> F2 VIN Licenses.
