Well, thats way better than 24 hours. Thats something you can order then go talk with the customer about what they want and then start right as you get the license...or start tuning then flash when you get it.
Im pumped!
which file in the folder is it ? it tells me i cannot open the files without the progam that created them? i dont understand how to add or open the files in that folder. its has things like LS1A and LS1B as file names?
open EFILive_Explorer.exe> config files tab
then navigate to C:\Program Files\EFILive\V8.1\Config.
you copy/move all of these files to the V2.
in the C:\Program Files\EFILive\V8.1\Config. there is the options .ini file
that is the file to edit before you move it to the V2.
you can do as Joecar suggested to show the WBO2 data but if you want to log
you own define PID selection with BBL you will need to change the options.ini
The analog AFR is not yet displayable on V2 BBL...
The serial AFR will be displayable with the next release of V2 firmware 2.06.01 (I am told)...
you will need a serial comms cable for connecting the FJO to V2.
