Well, It reads my Truck info and everything but the tune tool says the OS is not supported for it.
V7.5.7 (Build 235)
Email the file to [email protected] and mention that V7 says OS not supported...
also specify year/model/vehicle.
I email them already after I saw you comment. How long do they usually take to answer back?
Bump for 2013 Sonic OS #12655493...now I have one to tune!
Does anyone else have problems with the yellow monitoring button in V7 scan tool? I can't monitor PIDs. I have to use the red log button in order to see data. I've had this problem for the last few updates. It hasn't worked for probably 6-8 months.
Also, I guess the EDA PID list in V7 scan tool does not work??
Yellow button monitors data it does not record data. The charts show recorded data so you won't see any data on the charts while monitoring. The dash gauges should show data that is being monitored.
Why do you assume the EDA data does not work? What problems do you have with it?
I don't see any data at all on any gauges or charts. It seems like it starts to work for a split second then it pauses itself. When I click the paused button, it starts recording data.
When I select the EDA PID list, and hit record, the data screen locks up and you have to hit stop. Then if I select my normal PID list it works fine. Maybe I'm missing something. I'm good at that.
The yellow button is designed to do exactly that, start recording, but in pause mode so nothing gets recorded. In pause mde the data is displayed in the gauges and on the [Data (F9)] tab page but not in the charts.
EDA is for Cummins controllers that have been programmed with EFILive's custom operating system (that transmit the EDA data) only. IT won't work on any other controller or operating system.
EDA PID list is in the V7 software, but that function is not yet enabled. EDA and CSP will be in our next release (scheduled for next week). Once it's released, you'll find an upgrade document that explains how to get EDA to work, but the short version is you'll need to flash CSP into your ECM to gain access.
Cheers
Cindy
Is it possible the SD Card holder has failed? You can test the SD Card holder switches using the following option:
F4 Options -> F4 Self Tests -> F3 External Sensors -> F1 Display Sensors
Then apply pressure (up/down left right) to the SD Card and watch the two settings: SD:x and WP:x
Do either of them change from 0 to 1 or 1 to 0?
SD:x is 0 when the card is not present and 1 when the card is present.
WP:x is 0 when the card is not write protected and 1 when the card is write protected.
Those values should not change unless you remove the card or change the lock slider on the side of the card.
If they do change when you wiggle the card then the card holder has probably failed.
I have trouble reading LMM TCM's with this release in v7.5. I cant read, cal, or full flash a LLY ECM with V7.5 either. I also get a message that the LLY controller is locked when I try to scan the ECM so I can lock it. I can read it and write to it with V8 fine, but it says its locked in v7.5.:throw:
And just for fun, I put the ECM on my bench harness. Read the tune with V7.5 like a champ. I sure wish I could send EFI Live an LLY to play with. This is starting to get real annoying!!!
So....I tuned a LLY at the Dyno today with no glow plug module....and never had 1 issue using v7.5 to tune it. I did get it to lock the ECM, but it did not work properly and never finished the lock process process on my computer screen.....but the ECM is locked and I was able to unlock it. Tuned without pulling radio, radio amp, and info fuses too!!
Finally got a chance to test this - Apparently the SD slot is flaky :(. It doesn't change every time the card is touched, but it can be made to change without removing the card. The odd thing is you'd think it would just corrupt or lose the file it's working on when it happens, not corrupt the entire card...
