Thanks for the help guys....
Paul, is this a "quick" fix or do I need to find another way to add a wideband?
I do have a empty egr circuit I could use for input. (Thanks 5.7ute)
I'm using aem wideband and I don't have a serial plug I've been using analog input. I've been using plx pid's and the log shows .5 AFR lean(ie my wideband will show 15.2 and the log shows 15.7)...
Update:
It took most of today to find and fix the external PID issue. It was a larger problem than it first appeared. All changes are done. Testing will happen tomorrow. I expect to post an update with the problem fixed sometime tomorrow, assuming the testing all works out ok.
Nice!! Great job as always.
Any updates?
Update posted here: https://forum.efilive.com/showthread...te-Feb-09-2015
Thanks again Paul...
im having a problem like this but with the serial wideband lambda.. take the log. save it, close it, when i reopen it does not has the data of the wideband lambda :S, i gonna try the last update
Make sure you also download and install the obdiiV7.dll attachment that is explained in Issue 5 here:
https://forum.efilive.com/showthread...e-and-firmware
update;
I finally got time to play with my truck and all is well.....thanks again everyone that helped....cheers:thankyou2:
