TFT and GEAR PID's still dont work in BBL or scantool for my '06 alli 6 speed.
My serial w/b didnt work on the last update, hope it works on this one, will let u know how it goes.
cheers
You had the AEM UEGO, correct?
I am picking up my new welder tonight, so hopefully (If I can get a new outlet run to the garage) I can do some testing on it also.
I got the serial W/B working, was not to do with efi live but a broken solder connection. I have a Innovate w/b.
This update is working flawlessly, well done ,not to far away now.
when i click on the tune tool it pops up in demo mode and to register efi. i registered it and it still says in demo. just downloaded the latest 7.5.4. anyone have any solutions??
Did you open a tune yet? (There are sample tune files in the EFILIVE directory) I think it was part of the registration procedure.
I just did a fresh install of the latest version, and did not have this issue.
If it is on the wrong year, I found that you could click on "Today" at the bottom of the calendar, and it would be considerably closer to the date I purchased it.
BBL for P12 still says need to disable HOS2II , invalid PID .
I did the auto update on this latest release. I did not plug my v2 in and do anything since doing the update. Is there something I need to do to update my v2?
I try to log and my v2 can view the lm1 wideband but not while logging or scanning. it does not show on pid list since first time configureing my 8.1.
The last 2 updates does not show my wideband on the v2. I finally got my flash scan to show all the pids and now its not recording them for wideband in bbl.
here is a log of what is showing on my v2
Final got around to update my V2 to all the current crap. Ever since I did the update, I am having issues with the scanner linking to the PCM. Its says that the cable is disconnected. Then I disconnect the cable from the V2, replug it back in and then it finds the PCM. What is the issue??
Its a real pain in the ass. It seems like its only with the scanner. The tuning side links fine.
Howard
After performing the updates to the V2, I have noticed that it takes some time for the unit to boot up upon being plugged into the computer.
Have you got the following versions running (check in the Help->About wiondow)
Scanner: V7.5.4 build 64
v7obdii.dll: V7.5.4 build 64
Tuner: V7.5.4 build 64
FlashScan firmware: V2.05.18 (Check using FlashSCan options: F4->F3->F1 then scroll down.
If you are running all those versions, can you (after the link fails),
first: save a trace file in FlashScan.
second: generate an error report in the Scan Tool software.
Send both files to me at [email protected] with a link to this thread so I can correlate the two.
Now I don't feel sooo stupid......
If you're looking for FlashScan firmware: V2.05.18, (like I was) it does not seem to be downloaded to your machine by the Online Auto Updater as part of V8....
I actually had to manually download the installer file and WHA-LAH....There is was.....
After that it installed like a snap!
Hope this helps....
Chuck CoW
Chuck,
Where did you find the file?
HT
Normally, I find them here:
C:\Program Files\EFILive\V8.1\Firmware
but I don't have .18 either... I thought I downloaded all of the latest stuff (Not from the updater), but I did a find for '*efw' and I don't see it.
I have 2_05_17(0622).efw for the latest.
Maybe a moderator can just post the firmware file already so we can stop playing seek and destroy!
HT
It is in thr V8.1 folder...
but the auto update doesn't seem to pull that file in... you have to manually install 8.1.
Looks like I only had build 63 of the tuning tool. I (Think) am downloading 64 now.
Was this updated somewhere other than the first page of this thread?
Ok, so it is on the main download page, not in this thread:
http://www.efilive.com/download.aspx
I no longer have a v8 folder. The only thing I can find in files for v8 is the installer wizzard.
I was able to get my firmware to the latest 2.05.18 but dont know if I have to reconfigure my configurations tab. if so, I am shit out of luck because I cant even fiind the file options ini
It should be here : C:\Program Files\EFILive\V8.1\Config
Ok, so I've got my spare V2 up to the latest .18 firmware..NO PROBLEM.
My main tuning V2 has: Firmware: 2.04.67 date: nov 14 07 and boot block: 2.04.09 Date:28 oct 06
Problem is the old firmware tool says I can't use it cause I have v.2.05.xx or greater.....but, in the unit it says I've got v2.04...
SO, NONE of the explorer/firmware tools will talk to my main V2....It works ok, but paul says it's ready for the new firmware....Now, it just won't take.:confused:
Chuck CoW
Ok I went into my trash bin and pulled out an old version of v8. I went through the install wizzard again and installed again so that it would update the folder. I went through the configuration process but does not look like there were any changes made.
I will have to try it to see what it does in the car. Now that I am gettin somewhere, my lm1 is getting a sensor timeing error. I guess That means I need a new sensor?
^ New software.
I have attached a copy, if that didn't work, send me an email, and I will send it to you.
I will check the downloads. Sounds like maybe I messed up the V8.1 auto-update download.
Meanwhile, the latest of everything is available at the link nevinsb posted above (thanks).
Paul- Nice to see that you provide hand-holding services for beta testers.
By the way, what happened with the layout of the PIDs on screen? up until a few updates ago (I don't remember which), you could get 8 lines of data on screen, which was nice when looking at injector balance rates (to see all 8 at the same time).
I think we have all been quite patient and workable throughout this process. I wouldn't call in hand holding........ Many of us who use this software everyday have been a bit hesitant and also have not been able to follow all the hickups and changes along the way. Isn't this what the forum is about?
Paul,
We most certainly appreciate your teams efforts and continuing to develop a kick ass piece of software. Thanks for holding my hand..........LOL!!
HT
is there a way to speed up the loading of logged data? (and filters)
large log files seem to take forever to load at times.
Not in version 7. The log files are disk based and that makes everything slower.
In version 8 making fast/snappy redisplays was a high priority. To give you a comparison, a 50,000 frame log file can take 10-15 seconds to replot in V7. In V8 it is less than 1 second.
