Does that companys name start with a "V".......and they thought that they were so sneaky with their stealth tune and the correct CVNs :laugh:
I just had the truck in two weeks ago to have the reflash. Nothing was said, but is that info. stored at GM for the future that they could look back at in the future if I had a major break down? Was it downloaded and stored????
Well, first thing is this is not for a Bosch ECM, that is a very important point!
But I'll give them credit where it is due, the fact that they don't turn off the checksums and still have the matching CVN is good.
But the point I am trying to make is bypassing all these 'checks' GM puts in will only keep us safe for so long.
Ross, it is kind of like the hacked Direct TV H and HU cards a few years back. Some one hacks the code, then everyone can get free satellite TV, then Direct TV blasts the hacked cards with a signal wich renders them useless, then someone else comes up with a new hack and the cycle goes on and on. Finally Direct TV got a hold of some of the records of where the hacker equipment was sold and Direct TV hired lawyers to sue people for theft of services, some caved in and paid off DTV others held out and won. I see this coming to our world now and its only going to get worse as rules tighten up in the world of the EPA standards that govern the OBD2 regulations.
Not how I would do it, having the checksums functional is pretty important, but it could be done that way.
Exactly, they could make this whole tuning game too hard for companies like us. Piss them off enough and they will, that is how I view it.
The OEM 's have very strong motivations for preventing hacking:
1. EPA is on their case (the EPA can prevent the OEM from selling vehicles in USA),
2. Loss of revenue from warranty misclaims.
Jump Jump Jump!!!!!!!!
Can anyone tell me can they tell how long or when the tunes were installed?
Oh and by waiting for others to test the water doesn't mean waiting to see how it's done. Spoofing CRC's is common enough, it's not exactly 1+1 maths, but it's possible to do.
It does seem to be hit and miss when it logs a change (which is weird), if you changed the speedo segment 10 times then 'in theory' that should work, but I found that sometimes it didn't seem to log a change to other segments.
Would you guys ever have the ability to read the last 10 cals with EFI live?
CVN display is being written in to V2's firmware right now, I'll see if Paul might be able to add that too.
Thanks guys!
Sorry, but CVN display on the V2 didn't make it in to the next release, next time.
Probably might, then you would need to explain why your ECM has had so many different factory tunes programmed in to it.
That should not work, but I can give it a try. The information I heard states the engine cal OS CVN only gets written, if it is not one of the last 10 in memory
Well, I can tell you that there is STILL a bug in the way TechII displays the CVN v's the segment, the numbers are jumbled compared to the order shown on CalID. You need to do this crazy cross reference to match up the segment to the CVN.
I'm sure in my testing I have also seen speedo segement updates be recorded in the history list, though for some reason that does seem hit and miss too.
It is possible that it may not write a CVN if it already exists, but I would think that at the very least, the current Cal (the last one programmed) and its corresponding CVN would be the last one showing.
It sure would be interesting to see what would happen in a situation where two stock cals are alternated.
If this works and they asked why the same two cals so many times, one could say that you were testing driveability differences between the two cals. :angel_innocent: :grin:
Those of you worried about this please note that we stock the 2007.5-2010 ECM's by the CASE at a rate considerably lower than dealer cost and lower than others selling used ones as cores! If you need an ECM we'll be happy to flash one to OEM specs with the up to the minute release for your use as a spare or one to tune so you can save your stock one for dealer trips.
We picked up a TON of these just for this issue so if you need one please let us know!
Currently we do not carry them, we are looking at the possibility of carrying them however buying them in bulk this long after production is over is more than likely impossible. If we can get a few we will of course post up.
Programming wise the only thing we would need is your VIN.
OK.
Please, let me know if you are able to get one.
Thanks.
Will do, thanks for the interest!
Anything new on this subject?
You mean getting LBZ ECM's or clearing the programming history?
On the LBZ ECM's, not sure, on the programming history you might want to have a read of this thread to know it won't happen with EFILive.
http://forum.efilive.com/showthread....ght=CVN&page=4
Read my post on the CVN correction removal from the software.
Here's something on the LBZ (and LMM):
So let the panic ensue :PQuote:
INFORMATION
Bulletin No.: 08-06-04-006C
Date: October 29, 2008
Subject:
Information on Identifying Non-GM Calibration Usages for LBZ, LLY, LMM Duramax(R) Diesel Engine
Models:
2005-2009 Chevrolet Express, Kodiak, Silverado
2005-2009 GMC Savana, Sierra, TopKick
with 6.6L Duramax(R) Diesel Engine (VINs D, 2 , 6 - RPOs LBZ, LLY, LMM)
Supercede:
This bulletin is being revised to add the 2009 model year. Transmission programming information on potential Non-GM ECM Calibration or Power Up Hardware that does not involve ECM reprogramming was added. Please discard Corporate Bulletin Number 08-06-04-006B (Section 06 - Engine/Propulsion System).
Caution: Customers should be informed that even after the calibration has been returned to a GM certified configuration, it is likely that engine, transmission, transfer case and/or other driveline components were weakened to the point of premature failure while subjected to the higher stresses from the non-GM calibration (Power-Up Kit). Engine, transmission, transfer case and/or other driveline components where a non-GM engine calibration has been verified are not covered under the terms of the New Vehicle Warranty.
Power-Up Kit Detection - All 2007-2009 RPO LMM
For 2007-2009 applications, an Engine Control Module (ECM) algorithm was implemented that records the engine calibration part number and Calibration Verification Number (CVN) for the last 10 flash programming events. The ECM only records the engine calibration part number because it contains the parameters for increasing torque and fueling rates.
Some customers may have re-programmed the ECM with a non-GM released calibration. The (Power-Up Kit) powertrain calibration changes fueling and timing parameters and likely contributes to the following vehicle conditions:
^ Poor Performance
^ Black Smoke (This symptom is not valid for the 6.6L (LMM) diesel equipped with the diesel particulate filter (DPF). The DPF will trap black smoke unless the DPF is cracked, melted or has been removed from the exhaust system.)
^ Knocking Noise
^ Engine Damage (Refer to Service Bulletin Number 06-06-01-007 for additional information.)
If a vehicle comes in for service for a driveability/powertrain concern as a result of a Power-Up Kit installation, the dealership technician now can read the last 10 engine calibration part numbers and CVN history using a Tech 2(R).
The dealership technician would input each ECM calibration part number into the SPS/TIS2WEB CVN database to confirm the CVN history information. Refer to Tech 2(R) path table in this bulletin to verify ECM calibration.
2007-2009 LMM Tech 2 Powertrain Output Controls Path Table for NON-GM ECM Calibration
1. Build the vehicle with the Tech 2(R).
2 Select F0: Engine Control Module.
3. Select F5: Module Identification Information.
4. Select F1: Programming History.
5. Turn Ignition On and Engine Off. Press ENTER Key to Continue.
Important: An original production engine operation part number programmed in the ECM from the supplier, which is the last part number shown, would not be in the SPS/TIS2WEB database.
6. Record the Calibration I.D. Numbers and Verification Numbers from the Tech 2(R) Vehicle Information/Programming History Screen. If the list of Calibration Part Numbers is less than 10, the first Calibration I.D. Number (bottom of the list) will not be in SPS/TIS2WEB. In this case, the first Calibration I.D. Number is programmed at the Engine Control Module production factory and is re-programmed at the vehicle assembly plant.
7. From SPS/TIS2WEB, record the Calibration Part Number into the CVN Database. Get CVN.
^ If the CVN does not match the CVN database, an unauthorized engine calibration part was flash programmed into the ECM.
^ If the CVN matches the CVN database, we can assume a Power-Up Kit that flash programs engine calibrations was not used.
2005-2007 LLY and LBZ Instructions for Confirming Calibration Verification Number (CVN)
1. Go to TIS2WEB
2. Select "Calibration Information (SPS Info)"
3. Enter VIN
4. Select "Get Cal ID"
5. Select "ECM Engine Control Module"
6. Select "Next"
7. Select "Complete History"
8. Print
9. Take the printout to the vehicle along with the Tech 2(R)
10. Plug in the Tech 2(R)
11. Go to diagnostics and build the vehicle
12. Select "Powertrain"
13. Select "Engine"
14. *Select "Engine Control Module"
15. *Select "Module ID Information" or "I/M Information System" if module ID information selection is not available.
16. *If "I/M information System" was selected in step 15, it may be necessary to select "Vehicle Information" in order to display the calibration information.
17. Compare the calibration ID and Calibration Verification Numbers (CVN) to the Calibration Verification Numbers (CVN) on the printout.
* Steps may vary by controller.
Although the part numbers will be the same for each, it's the CVN that will determine if the calibration is GM issued. If ALL of the CVN's are EXACTLY the same, the calibration is GM issued.
If the part numbers match and ANY CVN's DO NOT match the printout, it is likely that a non-GM certified calibration has been installed.
If the CVN information is displayed as "N/A", it will be necessary to contact the TCSC to obtain the CVN information.
If a non-GM calibration is found to be in the ECM (CVN's on the Tech 2(R) do not match TIS printout) - In order to document the case -- a CLEAR digital picture should be taken of the Tech 2(R) screen showing the VIN and the CVN's (Programming History Calibration ID and Verification Numbers) that do not match the TIS2WEB printout. A copy of the digital pictures showing the Tech2(R) Vehicle Information/Programming History Calibration ID Numbers, Verification Numbers, Transmission Data, Tech2(R) VIN and reason the vehicle is currently in for service should be emailed for verification. Please copy your GM District Service Manager (DVM) in Canada (DSM) on the e-mail. GM will verify if the CVN's are not GM issued and respond via e-mail within 72 hours.
Tech 2 Transmission Data Path Steps for potential NON-GM ECM Calibration or Power-Up Hardware that does not involve ECM reprogramming.
An example of this hardware is a propane injection system. Data only available with the 2007-2009 GMC Sierra, TopKick and 2007-2009 Chevrolet Kodiak, Silverado.
The Transmission Control Module (TCM) algorithm is implemented that records a maximum calculated input torque. This information is available via the Tech 2(R).
2. Select F3: Transmission Control Module
3. Select F1: Data Display
4. Select F0: Transmission Data
5. Max Transmission Calc Engine Torque
6. The dealership should contact the PQC, open a case to review the findings. Before a final decision on warranty coverage is made.
A CLEAR digital picture should be taken of the Tech 2(R) screen showing the transmission data, Tech2(R) VIN and reason the vehicle is currently in for service should be emailed for verification. Please copy your GM District Service Manager (DVM) in Canada (DSM) on the e-mail. GM will analyze the transmission data and respond via e-mail within 72 hours.
Was the ability to read the current CVN ever implemented?
I assume when the stock tune is loaded back in with EFILive (LBZ) the CVN should return to stock?
Although that bulletin does say LLY,LBZ,LMM at the top, it only lists a procedure for checking the LMM so I ASSume that GM is only checking LMM's-which we have known for awhile. I did not know about the recorded torque input history in the TCM so maybe a guy needs to reflash the trans as well as installing a non tuned ECM.
"2005-2007 LLY and LBZ Instructions for Confirming Calibration Verification Number (CVN)
1. Go to TIS2WEB
3. Enter VIN
6. Select "Next"
8. Print
13. Select "Engine"
17. Compare the calibration ID and Calibration Verification Numbers (CVN) to the Calibration Verification Numbers (CVN) on the printout."
They are going to check the cal against the CVN on the older trucks according to this, not a big deal like the LMMs but if one of those segment CVNs are off on an LBZ you are screwed I guess.
It would be nice to check the CVNs without having to get a Tech 2 involved.
