We may take you up on this offer. The basic concept would be to take an existing VE Table (stock or otherwise), put the vehicle in closed-loop..attach wideband.
The pids selected would apply the LTFT Trims or WO2 reading (BEN). The computer code will 'know' if the vehicle is in closed-loop or PE Mode. After a log, you could apply the SELBEN correction to your existing VE Table. So VE Table, Trims all in one log. And you could have an accurate MAF Airflow equivalent should need you need it.
Once we get the thread going, you might be able to help us out with a log or two?
Thanks..
