Is there any easy way to move all my current tuning params from 12221588 to 12212156? I've have been away from the site for a while. Looking forward to tweaking a little on the car by playing with the TPS vs RPM VE function in COS5.
Unfortunately not.
You would need to start with a similar 12212156 file, as in a stock m6 or auto file depending on your trans. Then open both files seperately & copy/paste all the parameters over. Make sure it runs correctly then do the COS upgrade.
When V8 comes out this will be rectified, but until then you are stuck with this method.
What 5.7ute said...
use copy-with-labels and paste-with-labels as this helps the align the rows/cols for you.
Can you AutoVE ThrottleVE ??
Does the software expect the same units in TPS VE A0007 as it does for the MAIN VE B0101? If I'm in g*K/kPa, the default units I would put in would be the same right?
If in %, then %, etc?
Thanks...I am testing this later this week or on the weekend, so I look forward to reporting back and discussing results.
I would definitely use the same units for your TPS and main VE tables.
Use the VETABLE_dma pid to populate the TPS VE table initially.(without the TPS VE table enabled) Enable the TPS VE table, then use the autoVE process to fine tune it. Make sure you filter according to your TPS VE table enablers.
Use only [g*K/kPa]... set the tunetool to this.
