What I did all using ROADRUNNER:
Wrote 02020005 as cal and operating system. There are 3 choices, read, write cal, write cal and os.
Write CAL only of file from 12212156 that I converted from original tune file.
Read CAL and OS back and saved for tuning.
Made a few changes (disabled TPS VE so I could log first) and wrote it.
Turned key on, did not start engine. All seemed normal. Fuel pump came on, needles swing, looked like a normal startup.
Ok, time to set up scanner and log COL=TP, ROW=RPM and Data: g*K/kPa to create a starter TPS VE table.
SURPRISE, when I connect w/the scanner, it ask for a vin#. I input it and then it basically eliminates most of
my logging variables, including and especially VETABLE_DMA. So, I abort and keep trying to get it to recognize the logging
params.
Now the car is stuck in reduced power mode.
Ideas?
