Eyeball extrapolation.
I've read the tutorials and every thread related to OS5.
I cannot figure out how the table "Commanded Fuel vs RPM (Normal) should be set or it's function. {B3647}
I am setting up my PCM for simple nitrous spark retard. I think I have told the new OS to ignore TPS VE (Disable)
The tutorial talks about B3647 a bit and suggests initial settings. But I have not read on here that anyone has modified this table and or if it should just be set to 1.0
Any tips?
the B3647 has me stumped.
I don't have B3660
My original OS was 12212156
thanks,
Karl Ellwein
Thanks, the comparison will help a lot.
[email protected]
B3647 is the OL fueling table, it is used only in OL. If PE enables during OL then the richest of the two is selected (at the current operating cell).
B3647 is not used when you go from CL to WOT as in this case the residual LTFT is applied to WOT (i.e. in this case WOT is a reduced CL mode where even tho trims are not updated and applied, the last residual trim is applied).
You could do any of these:
a. set B3647 to EQR 1.0 everywhere (and make sure PE enables and is suitably rich at EQR 1.175 for NA).
b. set B3647 to EQR 1.0 below 75 kPa, and then ramp it up to EQR 1.175 (regardless of whether PE has enabled yet).
For NA you could have either PE and/or the high MAP columns of B3647 provide high load fueling.
For boost, you would enable PE at 105 kPa and set PE fuel suitably rich for boost.
Using B3647 means you will have to play with the OL ECT correction table A0008 (introduced by the COS in the A segment).
thanks a lot. That helps. Thanks Joecar and thanks TFZ_ZO6 for the file to let me compare.
One more question:
If you had an OK tune for B3647 for the car prior to installing the custom OS5 then would you paste that old table into new OS5 B3647 table as a starting point?
The GM OS does not have table B3647...
When you install the COS, it replaces B3605 (which is ECT x MAP) with B3647 (which is RPM x MAP), and it retains the old data that B3605 contained...
so your new B3647 looks like the old B3605, but because the vertical axis now RPM (instead of ECT), the data in this table is not completely sensible, you have to edit it (see my suggestions above).
i.e. B3647 occupies the same space as B3605, but it changes the vertical axis from ECT to RPM, so the ECT x MAP data is not valid, you have to edit it into sensible RPM x MAP data.
No worries :cheers: let me know how it goes.
