Many Thanks!
Many Thanks!
can someone please help me out? I'm very much a beginner at tuning trying to do this calcvet thing, I have all the pids selected and maps made but when I log & then go to the calc.vet map its just got 0.0 in all of the cells. What am I doing wrong?Attachment 11755
The log file needs to know what size your engine is to calculate VE%. With that log file open click Edit>>log file information and select your engine size. You may need to save, close, reopen for it to take, I got lucky on that step.
Make your life easier by changing your units to G*K/Kpa instead of VE%. Also make sure you are working in EQ ratio (which from what I gather is the inverse of Lambda).
thank you... I had set the engine size but didnt try saving closing & reopening that did it, thanks
Im new to this CalcVet can somebody check out my log and tune see if im doing ok for a newbie
The roads where water so i baby the car loging. Tomorrow we will be doing some WOT logs
This is a Stock LS7 in a 2002 Camaro with 460 RWHP
Attachment 11851
Attachment 11852
Is that .tun file the before file...?
The log file produces maps which look correct.
Yes joecar its the tune i logged with . i need to do these 1 thru 5 setting changes then log for 45 to 60 mins right .
1. B0701: Disable Catalytic Converter Protection
Insures accurate stoich and PE mode/WOT Fueling
2. B0120: Change RPM Threshold for Airflow Calculation from 4000 to 400
Eliminates any Airflow Correction from the VE Table
3. B3308: Disable DFCO: Change B3308 (M6) to 140C Change B3313 to 140C
Accurate fueling computations
4. B4105: O2 Switch-points to 450 Millivolts
Smoother MAF & VE Table
5. B3618: PE Modifier Based on Rpm (EQ): 1.16
the tune is before the log . i was going to go a better log before editing the tune. i think tomorrow we will be able the do a 45 min to 60 min log .
Ok.
Just done done a Calc VET and things look good except my Idle, my idle is rich when cold, around 12.5 then goes up to around 14.5 when warm. I've also noticed that when slowing down my revs drop quite low but the motor doesn't stall. I didn't think a Calc VET would affect idle since you filter out cells below 800 rpm, I do see one cell at 800rpm-60kpa. Do I need to re tune Idle, I've also attached a copy of my Calc VET log.
Thanks!!
