On the PIDs tab, on the invalid pid do rightclick>More Info, this will explains why he pid is invalid (it might need other pids to be selected).
Paste the More Info text for those pids here (highlight the text and do ctrl-C to copy it).
Hi, this may be a stupid question, but what does BEN stand for? I see it used a lot through tis posting.
BEN is a contrived term, Base Efficiency Numerator, also named after Ben Strader of EFI University.
it is easier to say/write "BEN" than it is to say "wideband fueling correction multiplier".
BEN is equal to all of these:
- commanded EQR * measured Lambda
- commanded EQR / measured EQR
- measured Lambda / commanded Lambda
- measured AFR / commanded AFR (if both commanded and measured assume the same value for stoichiometric AFR).
Thanks Joecar!
So when I see words like selben or WO2ben it is all to do with data/information from the wide band O2 sensor?
Also I have a stock LS1 out of a VZ Calais in my landcrusier. The information I got from the Marks4wd adaptor site suggested that I should run my rail pressure @ 65psi. The holden work shop manual says that the pressure as standard is 59psi. Should I lower my pressure down to 59psi and keep the stock fuel injector settings or keep it at 65psi and change the fuel rail pressure setting using the excel sheet mentioned in this post?
I am gearing up to carry out the Calc Vet tuning on my engine so I am trying clear up a few questions I have before I hit the road logging.
Another thing, I hear about open loop with MAF. How do I set up for that? I want to keep my MAF at this stage, but do I have to be in open loop for the Calc Vet tuning to work? I am only new at this tuning and I am trying to get this clear in my head.
Cheers
Calculated VE, Not corrected {CALC.VEN}
Expression:
% = {SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C}+273.15)/{SAE.RPM}/{SAE.MAP.kPa}*3445.2/displacement()
is NOT valid because:
Required parameter {SAE.MAF.gps}, at position 14 is not selected.
PID value cannot be determined because
the following error would occur:
Expression not valid: Required parameter {SAE.MAF.gps}, at position 14 is not selected.
Expression:
g*K/kPa = {SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C}+273.15)/{SAE.RPM}/{SAE.MAP.kPa}*15
Expression not compiled
so i logged gm.maf not sae.maf. Is there any difference in these pids? It's kinda hard to know exactly which pid you're selected in the v8 interface because it doesn't list gm.maf it lists "Air Flow Rate from Mass Air Flow Sensor" so there's no telling exactly what you're selected
SAE.MAF = PCM reports what MAF says, even when MAF has failed.
GM.MAF = PCM reports what MAF says, but when MAF fails the PCM reports calculated MAF (i.e. what it should say based on calculation from VE, MAP, RPM, DAT).
See post #2 here: Summary-Notes
very helpful, i've got that thread bookmarked now
how would you describe the differences between GM.DYNCYLAIR and GM.DYNCYLAIR_DMA?
GM.DYNCYLAIR
PCM calculated cylinder airmass [g/cyl] based on VE.
GM.DYNCYLAIR_DMA
Internal PCM calculated cylinder airmass [g/cyl] based on VE.
There are almost the same;
the _DMA pid is the lookup of an internal calculation, which Paul says the PCM uses for looking up spark.
I"ve been out of the gas tuning game for awhile, wow stuff got more intense lol. I'm currenlty reading this thread again but it's so long. Can someone please just direct me to the very newest tutorial and calc.pids text so I can start to be on my way. I'm helping a friend tune his 99 vette with a LC-1 and efilive. The only mods I know of are an exhaust (not full) and a Cold Air Intake. Thanks all.
