Have you tried it on something obvious....like idle speed or something so you can deffinately notice a difference?
You type in the change and hit 'enter'?
I guess you were in realtime mode too? I have not had this problem. I have made the mistake of having a filter set and forget to uncheck it, caused no rr activity. That caused me a headache one night for about an hour.
With all this talk, its time to go out and play with it again.
Yes, I thought that was the most obvious thing to do. I changed idle speed, sent the change to RR, and nothing happened. It's been a few weeks since I played with it, so I'll try again and see if there's a filter issue or something else I missed. Thanks for the suggestions.
Mine hasnt got the mini usb on it? Might be one of the earlier ones.
http://i245.photobucket.com/albums/g...76/RR-Guts.jpg
Might be best to get in touch with Craig Moates.
Hi, I'm subscribed to this thread, just happen to be surfing and happened to
talk to Craig about another issue (non EFI/RR related). I mentioned your post. He recommended a Ferrite Bead:
http://www.moates.net/product_info.p...roducts_id=202
