The Allow Cax option only allows particular overlaps... and what B9000 is overlapping is not allowed.
Ok, I think I got it. I copied 'cax b.cax' and renamed it to 02020005.cax, then pasted the B9100 section at the end. For some reason my PC didn't want to upload the .cax file so I added the .txt extension. Thanks Joe.
It loaded w/o error (Allow cax option checked), thanks again.
How does one go about checking the .cax overlap? I did the Properties>Option>Allow .cax etc... and the tune loads without error now but it seems to still screw with the tune.
If you enable the Allow Cax option then the tunetool should continue to allow the cax overlap as previous...
I have the same problem after updating this week. I selected the option to allow cax and downloaded tinindian's cax file above and I still get the warning B9000 not allowed, overlap, etc. every time I open a 12212156 tune file.
I haven't run a lean cruise tune in a few years, but with this problem, would it load into the PCM if I tried it?
