Sorry about that. Now I understand what you mean. Thanks:grin:
but even if we trim the efans down so that the fans touch the rad what about this part under the rad that supports the efans? How would we support the bottom of the efans then?
http://img407.imageshack.us/img407/2362/efanrad2hz8.jpg
No, remember the LS1/LT1 fans operate in an on/off only manner, they are NOT PWM like the stock mechanical ones or the C6 Vette. All we are doing by setting them to 0 is telling the PCM to not try and ever turn them on. If it never tries to turn them on (and we enable the efans parameters and kills the DTCs), it never tried to do anything related to the fans. Plus, we are not actually controlling the efans from the PCM with these tables, this is why you need an aftermarket controller. Im not sure, but I imagine if you set the tables to 100% when you wanted the fans to come on you might be able to use the stock PCM output to drive the relay. This is how the SS guys do it, I cant experiment with it though.
