Yes it will work. Your better off setting the ECM up as a LBZ by changing the Engine calibration segment. PM me if you need help.
If I recall it won't work for the Van application because the trans is not an Ally
I installed switches on, built tunes for, and tuned 2 LBZs today. They both worked perfectly with no problems.
i cant figure out how to get build 99 i have build 88 and cant find an update??? help
The first post in this post has the link to the new files.
Brian
right on-csn't wait to try this once i get some pins!!
A very small flat jeweler's screwdriver works well. I think they make a tool for it.
