joecar,
I think we argue over semantics. I learned this stuff without ever reading a book or taking a class(used internet). I started this in the days of the GM 7747 ECU(hated those). My verbiage is usually wrong and my thinking is sometimes wrong.
I am eager to get some basic tuning done in order to see if I have wrecked the VE MAF relationship. I have been rough on the tables. Got fairly good at bashing in tables from setting up aftermarket EFI on most any engine combo that people wanted to build. This MAF system is slightly different and considerably more balanced. It is good that I decided to learn this system on a stock engine(read: easy).
Questions:
1- What are you doing with all of the other(not main) 3d timing tables?
2- Is there a big problem when they are not close to the main table?
3- Do you think I should analyze them in relation to the stock main table and and apply those differences to them based on my final modified main table?
4- Should #3 be done before any serious tuning?
5- What is ICE textbook?
I'll leave you alone after this,
S
PS, Seems that edits are emailed to subscribed members. I been goofin with BB code. Must look like a GOOF.:unsure:
