Copy mr.pricks Settings.dat (unzipped from Settings.zip) to C:\Documents and Settings\All Users\Application Data\EFILive\V8\Config...
and then start the S&T software, goto F6: Device Settings,
Goto the tab F8: Serial I/O tab and check these settings:
- set Com Port to Wideband,
- set Wideband to Innovate,
- set Format to 1st or Both,
- Set Data Display to AFR and Lambda.
Goto the tab F6: BBL (Logging) and check these settings:
- set Automatically log external digital pids.
Then click Save to save to file, and then click Program to program these settings into your V2, and close S&T.
