Could someone verify if this PID list is correct for CALC.VET, there are a few that have different descriptors than what's shown in the how-to. Do I delete the serial wb PID since I have the NGK analog PID at the bottom? (That's what I'm using). Also all my calc PIDs are typed in the V7 pop up box so I believe i'm set there. Thanks in advance.
On a side note...I know it's been a while since anyone posted on this thread but i've been reading all week on this forum to find my missing calc pids and started wondering if it was a V7/V8 issue, as it is. There are many outdated how-to's with seemingly high priority. Most of my frustration with this software comes from reading outdated info. From using the setup CD when I first got it and thinking I couldn't use BBX features when my laptop quit to reading 11/48 pages of the CALC.VET tutorial thread and realizing I had wasted alot of time. It's easy to get sidetracked reading about the issues of others, after all you might learn something, but i'm still trying to get the basics down and it ends up being wasteful of time (relative to the task at hand) and overwhelming.
EFI_V8PIDS
PCM.MAF_GM
PCM.DYNAIRTMP_M
PCM.EQIVRATIO
EXT.WO2LAM1
PCM.MAP
PCM.LONGFT1
PCM.LONGFT2
PCM.MAFFREQ
PCM.TP
PCM.CYLAIR_M
PCM.RPM
PCM.DYNCYLAIR_M
PCM.ECT
PCM.HO2S11
PCM.IAT
PCM.KR
PCM.HO2S21
WO2A.AFR_NGK1
