Ok call me stupid but it looks just like what i already had.
And ive used this os already in camaros with zero issues.WORKED PERFECTLY thats why i like to use it.Hmm
Its out of range because EFILive doesnt populate those areas of memory. If GM didnt (no need in factory OSs) and EFILive doesnt do it for you, you MUST do it manually. LB7/LLY DSPx are the same way, have to script sane values into all the new tables because they can have random or no values.
Ive gone through and added sane values to all the COS tables. It is not using the TPS or Boost VE tables, just the N2O Monitor. N2O VE multiplier has been set to 1 so no VE corrections will be made.
Its not the COS, it could be the Camaros dont have anything in those memory areas so you're ok not adjusting the values. This truck OS might and is causing your problems. ALWAYS fill in COS tables with sane values otherwise the motor could go boom down the road if one of the tables becomes activated.
Dang, Joe and Andrew beat me to it. Again. :D
Ok thats fine and dandy but all the values look exactally the same when i open up the custom portion of the tune.And THANKS for all the help thus far guys.
Im just not seeing (when i open the file) the changes.I see stuff in the history but in the file it self it looks exactally the same as before.Now i just feel like a moron
Scarab thanks for the changes,i actually was going to do the 50% on the hi low blending.I just hadnt had that chance cause i was trying to just make it work first lol.Tanks though.I still dont understand how all the A0000 threw A0018 were out of range when its the exact same things that were already there.Not to mention i had changed some of the items that were out of range to what there set to now.
Here is a photo in case anyone finds it useful:
High Resolution Photo Red Pin 56:
Ok looking at all the parameter files to me those didnt change.But do you have to set them to something different first then fill them back in.If so i understand that.
I do see that the tpsve and boostve stuff changed and a few other things.
I understand that Joe but where do i view this to make the changes.
as you said in your email you changed a0001 from 1600 to 99
In mine it was set to 100.And all i saw was 100.Im sorry im just not understanding.Where am i not looking to see what everyone else is seeing.
Look at these threads:
Quote:
Fixing Out Of Range Cells:
showpost.php?p=87052 post #14
showthread.php?14119-3000-RPM-max-and-setting-codes-03-Z06-with-Magnuson-at-150kPa posts #14, #17
showthread.php?14654-I-need-help-getting-the-most-out-of-my-car post#2
